G-code, M-code, and Setting
Service Home G04 Dwell (Group 00)
P - The dwell time in seconds or milliseconds
NOTE
The P values are modal. This means if you are in the middle of a canned cycle and a G04 Pnn or an M97 Pnn is used the P value will be used for the dwell / subprogram as well as the canned cycle.
G04 specifies a delay or dwell in the program. The block with G04 delay for the time specified by the P address code. For example:
G04 P10.0. ;
Delays the program for 10 seconds.
NOTE
G04 P10. is a dwell of 10 seconds; G04 P10 is a dwell of 10 milliseconds. Make sure you use decimal points correctly so that you specify the correct dwell time.
