G-code, M-code, and Setting
Service Home G100 Disable / G101 Enable Mirror Image (Group 00)
*X - X-axis command
*Z - Z-axis command
* indicates optional. At least one is required.Programmable mirror image can be turned on or off individually for the X and/or Z Axis. The bottom of the screen indicates when an axis is mirrored. These G codes are used in a command block without any other G codes and do not cause any Axis motion. G101 turns on mirror image for any Axis listed in that block. G100 turns off mirror image for any Axis listed in the block. The actual value given for the X or Z code has no effect; G100 or G101 by itself has no effect. For example, G101 X 0 turns on X-axis mirror.
NOTE: Settings 45 and 47 may be used to manually select mirror image.
