G-code, M-code, and Setting
Service Home G105 Servo Bar Command
This is the G-code used to command a Bar Feeder.
G105 [In.nnnn] [Jn.nnnn] [Kn.nnnn] [Pnnnnn] [Rn.nnnn] (XXXX.YYYY)
I - Optional Initial Push Length (macro variable #3101) Override (variable #3101 if I is not commanded)
J - Optional Part Length + Cutoff (macro variable #3100) Override (variable #3100 if J is not commanded)
K - Optional Min Clamping Length (macro variable #3102) Override (variable #3102 if K is not commanded)
P - Optional cutoff subprogram
Q - Allows special bar modes to be set.
Comment - Optional Calls subprogram similar to a P code above. The file extension  YYYY can be no more then four charters long.
I, J, K are overrides to macro variable values listed on the Current Commands Page. The control applies the override values only to the command line in which they are located. The values stored in Current Commands are not modified.
Only two Q modes are available Q0 (Normal Bar Feed) and Q13 (New Bar Face Off).
NOTE
A G105 with a J code will not increment the counter. The J code is intended for double push operation to make a long part.
WARNING
If the control can not find a program with when using either a comment or P code alarm 314.Subprogram Not in Memory will be generated
WARNING
If there is a comment in line with a G105 that contains text formatted like XXXX.YYYY the control will try to find a subprogram with that name and when it fails generate alarm 314.
Example:
G105 (0.50=12.7 inch to mm)
The comment noting that 0.5 inches equals 12.7 mm will generate alarm 314 since the control will look for program 0.50. Because of this it is best practice to move all comments on lines with G105 to their own line above or below the G105 line.
