G-code, M-code, and Setting
Service Home G172 Diameter Programming Override (Group 20)
This G-Code overrides setting 285 X Diameter Programming to use diameter programming. When G172 is active all programmed inputs to the X-axis will be interpreted as diameter.G171 and G172 reactions to the following program end M-codes:M00 -- Stop Program -- No change. Active G-code remains active.
M01 -- Optional Stop -- No change. Active G-code remains active.
M02 -- Program End -- Resets G171 or G172 back to the default of setting 285.
M30 -- Program End & Reset - Resets G171 or G172 back to the default of setting 285.
