G-code, M-code, and Setting
Service Home G195 / G196 Forward/Reverse Live Tool Radial Tapping (Diame...
G195 Forward Live Tool Radial Tapping (Diameter) / G196 Reverse Live Tool Radial Tapping (Diameter) (Group 09)
F - Feed Rate per revolution (G99)
* U - X-Axis incremental distance to the bottom of hole
S - RPM, called prior to G195
X - X- Axis absolute position at the bottom of hole
* Z - Z-Axis absolute position motion command
R - Position of the R plane
* C - C-Axis absolute motion command
* Y - Y-Axis absolute motion command
* W - Z-Axis incremental motion command
* Q - Peck Depth (always incremental)
* E - Chip-clean RPM (Spindle reverses to remove chips after each hole)
* indicates optional
This G-code is modal in that it activates the canned cycle until it is canceled or another canned cycle is selected. The cycle begins from the current position, tapping to the X-Axis depth specified. An R plane can be used.
S RPM should be called out as a positive number. It is not necessary to start the spindle in the correct direction;
the control does this automatically.
G195/ G196 Live Tooling Rigid Tapping: [1] Rapid, [2] Feed, [3] Start or end of stroke, [4] Starting point, [5] Part surface, [6] Bottom of the hole, [7] Centerline.
o61951 (G195 LIVE RADIAL TAPPING) ;
(G54 X0 Y0 is at the center of rotation) ;
(Z0 is on the face of the part) ;
(T1 is a tap) ;
(BEGIN PREPARATION BLOCKS) ;
T101 (Select tool and offset 1) ;
G00 G18 G20 G40 G80 G99 (Safe startup) ;
G00 G54 X3.25 Z-0.75 C0. (Start Point) ;
M08 (coolant on) ;
(BEGIN CUTTING BLOCK) ;
S500 (Select tap RPM) ;
G195 X2. F0.05 (Taps to X2., bottom of hole) ;
G00 C180. (Index C-Axis) ;
G00 C270. Y-1. Z-1. (Index C-Axis, YZ-axis positioning) ;
G80 (Cancel Canned Cycle);
(BEGIN COMPLETION BLOCKS) ;
G00 Z0.25 M09 (Rapid retract, coolant off) ;
G53 X0 Y0 (X & Y home) ;
G53 Z0 (Z home) ;
M30 (End program) ;
