G-code, M-code, and Setting
Service Home G251 Scaling (Group 11)
NOTE: You must purchase the Rotation and Scaling option to use this G-code. A 200-hour option tryout is also available; refer to Option Tryout for instructions.
*X - Center of scaling for the X Axis
*Y - Center of scaling for the Y Axis
*Z - Center of scaling for the Z Axis
*P - Scaling factor for all axes; three-place decimal from 0.001 to 999.999
*indicates optional
G251 [X...] [Y...] [Z...] [P...] ;
The control always uses a scaling center to determine the scaled position. If you do not specify a scaling center in the G251 command block, then the control uses the last commanded position as the scaling center.With a scaling (G251) command, the control multiplies by a scaling factor (P) all X, Y, Z, A, B, and C end points for rapids, linear feeds, and circular feeds. G251 also scales I, J, K, and R for G02 and G03. The control offsets all of these positions relative to a scaling center.There are (3) ways to specify the scaling factor:A P address code in the G251 block applies the specified scaling factor to all axes.
Setting 71 applies its value as a scaling factor to all axes if it has a nonzero value and you do not use a P address code.
Settings 188, 189, and 190 apply their values as scaling factors to the X, Y, and Z axes independently if you do not specify a P value and Setting 71 has a value of zero. These settings must have equal values to use them with G02 or G03 commands.
G251 affects all appropriate positioning values in the blocks after the G251 command.
