G-code, M-code, and Setting
Service Home G266 Visible Axes Linear Rapid %Motion (Group 01)
G266 Visible Axes Linear Rapid %Motion (Group 00)
E - Rapid rate.
P - Axis parameter number. Example P1 = X, P2 = Y, P3 = Z.
I - Machine coordinate position command.
The below example commands the X-axis to move to X-1. at 10%
rapid rate.
G266 E10. P1 I-1. (RAPID AXIS #1, X, AT 10%, TO MACHINE POSITION -1.0) %
To use the bar feeder pushrod as a stop. The example below is commanding the bar feeder axis to move to -10. From home (left side) @ 10% rapid rate.
G266 E10. P13 I-10. (RAPID AXIS #13, V, AT 10%, TO MACHINE POSITION -10.0) %
To load the pushrod, select [RECOVER] then there is an option to load the pushrod.
NOTE
Make sure to retract the pushrod before machining.
