G-code, M-code, and Setting
Service Home G268 / G269 Feature Coordinate System (Group 14)
X - Feature coordinate system origin X coordinate in the WCS.
Y - Feature coordinate system origin Y coordinate in the WCS.
Z - Feature coordinate system origin Z coordinate in the WCS.
*I - Rotation of feature coordinate system about working coordinate system X axis.
*J - Rotation of feature coordinate system about working coordinate system Y axis.
*K - Rotation of feature coordinate system about working coordinate system Z axis.
*Q - Qnnn is used to define the order in which the I,J,K rotations will be applied. The default value used if Q is omitted, Q321 rotates about Z, then Y, then X. Q123 rotates about X, then Y, then Z.
* I, J, K is optional for Gimbal Lathes*I, J, K is required for regular Lathes*Q is optional
NOTE: If you intend to use G268 or G269 with G234 then G268 must be called first or Alarm 2062 TCPC OR DWO INCOMPATIBLE CODE will be generated.
NOTE: G268 and G269 only work on gimbal head machines (HDC-5AX, VR, etc.) and UMCs. These G codes are not currently available on vertical or horizontal mills with 4th or 5th axis.
G268 is a 5 axis G-Code used to define a tilted feature coordinate system relative to the working coordinate system. Canned cycles and G-codes work normally within the feature coordinate system. Before activating G268, G43 Tool Length Compensation, must be activated. However, the transformation from the working coordinate system to the feature coordinate system is performed independently from the tool length offset. Calling G268 only establishes the feature coordinate system. It does not cause motion in any axis. After calling G268 the current position of the spindle must be recalled. G269 is used to cancel G268 and revert back the WCS.There are two ways to define a feature coordinate system using G268. The first is to command the B (only on Gimbal Lathes) and C axis to the desired angle and specify only the feature coordinate system origin using G268. The feature coordinate system plane will be the plane normal to the spindle axis at the moment G268 is called.
NOTE: G99 + G268 is only supported for use with live tooling, not for use with the lathe spindle turning.
