G-code, M-code, and Setting
Service Home G50 Spindle Speed Limit
G50 can be used to limit the maximum spindle speed. The control will not allow the spindle to exceed the S address value specified in the G50 command. This is used in constant surface feed mode (G96).
This G code will also limit the secondary spindle on DS-Series machines.
N1G50 S3000 (Spindle rpm will not exceed 3000 rpm) ;
N2G97 M3 (Enter constant surface speed cancel, spindle on) ;
NOTE
To cancel this command, use another G50 and specify the maximum spindle RPM for the machine.
