G-code, M-code, and Setting
Service Home G110-G129 Coordinate System #7-26 (Group 12)
These codes select one of the additional work coordinate systems. All subsequent references to axis positions will be interpreted in the new coordinate system. Operation of G110 to G129 is the same as G54 to G59.
A10J-SCLCR0408, 10mm Ø Steel Shank Internal (ID) Boring Bar, Right-Hand, Screw-Lock, Through-Tool Coolant $49.95 $42.97
5/8"-11 UNC HSS-E Spiral Flute Tap, 0.48" Shank x 0.748" Thread Length, 2.5XD, Mod. Bottoming, 4 Flute, GH5, TiN Coated $59.95 $41.97
