G-code, M-code, and Setting
Service Home G154 Select Work Coordinates P1-P99 (Group 12)
This feature provides 99 additional work offsets. G154 with a P value from 1 to 99 activates additional work offsets. For example G154 P10 selects work offset 10 from the list of additional work offsets.
NOTE: G110 to G129 refer to the same work offsets as G154 P1 through P20;
they can be selected by using either method.
When a G154 work offset is active, the heading in the upper right work offset will show the G154P value.
NOTE: The P values are modal. This means if you are in the middle of a canned cycle and a G04 Pnn or an M97 Pnn is used the P value will be used for the dwell / subprogram as well as the canned cycle.
G154 work offsets format#14001-#14006 G154 P1 (also #7001-#7006 and G110)#14021-#14026 G154 P2 (also #7021-#7026 and G111)#14041-#14046 G154 P3 (also #7041-#7046 and G112)#14061-#14066 G154 P4 (also #7061-#7066 and G113)#14081-#14086 G154 P5 (also #7081-#7086 and G114)#14101-#14106 G154 P6 (also #7101-#7106 and G115)#14121-#14126 G154 P7 (also #7121-#7126 and G116)#14141-#14146 G154 P8 (also #7141-#7146 and G117)#14161-#14166 G154 P9 (also #7161-#7166 and G118)#14181-#14186 G154 P10 (also #7181-#7186 and G119)#14201-#14206 G154 P11 (also #7201-#7206 and G120)#14221-#14226 G154 P12 (also #7221-#7226 and G121)#14241-#14246 G154 P13 (also #7241-#7246 and G122)#14261-#14266 G154 P14 (also #7261-#7266 and G123)#14281-#14286 G154 P15 (also #7281-#7286 and G124)#14301-#14306 G154 P16 (also #7301-#7306 and G125)#14321-#14326 G154 P17 (also #7321-#7326 and G126)#14341-#14346 G154 P18 (also #7341-#7346 and G127)#14361-#14366 G154 P19 (also #7361-#7366 and G128)#14381-#14386 G154 P20 (also #7381-#7386 and G129)#14401-#14406 G154 P21#14421-#14426 G154 P22#14441-#14446 G154 P23#14461-#14466 G154 P24#14481-#14486 G154 P25#14501-#14506 G154 P26#14521-#14526 G154 P27#14541-#14546 G154 P28#14561-#14566 G154 P29#14581-#14586 G154 P30#14781-#14786 G154 P40#14981-#14986 G154 P50#15181-#15186 G154 P60#15381-#15386 G154 P70#15581-#15586 G154 P80#15781-#15786 G154 P90#15881-#15886 G154 P95#15901-#15906 G154 P96#15921-#15926 G154 P97#15941-#15946 G154 P98#15961-#15966 G154 P99
