G-code, M-code, and Setting
Service Home G268 / G269 Feature Coordinate System (Group 14)
X - Feature coordinate system origin X coordinate in the WCS.
Y - Feature coordinate system origin Y coordinate in the WCS.
Z - Feature coordinate system origin Z coordinate in the WCS.
* I - Rotation of feature coordinate system about working coordinate system X axis.
* J - Rotation of feature coordinate system about working coordinate system Y axis.
* K - Rotation of feature coordinate system about working coordinate system Z axis.
* Q - Qnnn is used to define the order in which the I,J,K rotations will be applied. The default value used if Q is omitted, Q123 rotates about X, then Y, then Z. Q321 rotates about Z, then Y, then X.
* indicates optional
NOTE
If you intend to use G268 or G269 with G234 then G268 must be called first or Alarm 2062 TCPC OR DWO INCOMPATIBLE CODE will be generated.
G268 Feature Coordinate System
G268 is a 5 axis G-Code used to define a tilted feature coordinate system relative to the working coordinate system. Canned cycles and G-codes work normally within the feature coordinate system. Before activating G268, G43 Tool Length Compensation, must be activated. However, the transformation from the working coordinate system to the feature coordinate system is performed independently from the tool length offset. Calling G268 only establishes the feature coordinate system. It does not cause motion in any axis. After calling G268 the current position of the spindle must be recalled. G269 is used to cancel G268 and revert back the WCS.
There are two ways to define a feature coordinate system using G268. The first is to command the B and C axis to the desired angle and specify only the feature coordinate system origin using G268. The feature coordinate system plane will be the plane normal to the spindle axis at the moment G268 is called.
O00001 (G268 WITH G81 DRILL CANNED CYCLE)(ANGLE FROM SPINDLE POSITION);
T1 M06 (TOOL CHANGE);
G54 G00 G40 G80 G17 G90 (GENERAL SAFE STARTUP LINE);
X0 Y0 S1500 M03 (INITIAL XYZ LOCATION);
G00 B30. C45. (SET SPINDLE ANGLE);
G43 Z6. H01 (ENACT TOOL LENGTH COMP.);
G268 X2. Y2. Z0 (SET TILTED PLANE);
G00 X0 Y0 Z.5 (RECALL POSITION);
G81 G98 R0.1 Z-1. F75.;
G80;
G269 (CANCEL TILTED PLANE);
G00 G53 Z0 M05;
G53 B0 C0;
G53 X0 Y0;
M30;
The second way to define a feature coordinate system using G268 is to use the optional I, J, K, and Q address codes to specify rotation angles relative to the WCS and rotation order. By using this method, a feature coordinate system that is not normal to the spindle axis may be defined.
O00002 (G268 WITH G81 DRILL CANNED CYCLE)(COMMAND ANGLE WITH IJK & Q);
G43 Z06. H01 (ENACT TOOL LENGTH COMP.);
G268 X2. Y2. Z0 I0 J30. K45. Q123 (SET TILTED PLANE);
G00 X0 Y0 Z.5(RECALL POSITION);
G80;
G00 G53 Z0 M05;
G53 B0 C0;
G53 X0 Y0;
M30;
