G-code, M-code, and Setting
Service Home M158 - Mist Condenser On / M159 - Mist Condenser Off
M158 Mist Condenser On / M159 Mist Condenser Off
M158 turns on the Mist Condenser, and M159 turns off the Mist Condenser.
NOTE: The mist condenser will run continuously if a program is running with axis motion.
NOTE: An M158 in MDI will activate the mist condenser for 10 seconds, after this the mist condenser will turn OFF. If continuous operation is required the program will require feed motion of at least one axis.
NOTE: If you want the mist condenser to remain ON, then go to CURRENT COMMANDS>DEVICES>MECHANISMS>MIST CONDENSER and press [F2] to turn it on
