G-code, M-code, and Setting
Service Home M174 Programmable Main Chuck Pressure Adjustment / M175 Pro...
M174 Programmable Main Chuck Pressure Adjustment / M175 Programmable Sub-Spindle Chuck Pressure Adjustment
Starting in Software Version 100.21.000.1130 the Main Spindle Chuck and Sub-Spindle Chuck pressure can be programmed two ways:The Mechanisms tab. Current Commands> Devices> Mechanisms. To set the Chuck Pressure in the Mechanisms tab: Navigate to the Main Spindle/Sub Spindle Chuck Pressure device. Type in the desired pressure and press [F2]
By M-Code. M174 Pnnn for the Main Spindle and M175 Pnnn for the Sub-Spindle.
NOTE: This is a machine option and must have the hardware to support it. There is no manual valve to adjust pressure.
NOTE: The value entered must be an integer (Whole Number).
NOTE: The maximum pressure depends on the chuck size. If the entered value is out of range a message will display pressure entered is out of allowable range.
NOTE: To decrease the pressure the spindle must be stopped and the chuck unclamped and then the pressure adjusted and then the chuck clamped again.
NOTE: The pressure specified with a M-Code will persist until a new pressure is specified either in Mechanisms or another M-Code.
