G-code, M-code, and Setting
Service Home M299 APL / Part Load / or Program End
During APL mode, use a M299 instead of an M30 at to have the APL load parts automatically. Refer to the APL set up section.When not running in APL mode the M299 takes the place of an M30 or M99 at the end of a program.Also when running in Memory or MDI mode, pressing [Cycle Start] to run the program, the M299 will behave the same as an M30. It will stop and rewind the program back to the beginning.APL Mode screenTo run in APL mode, Press [Current Commands] , navigate to Devices, arrow to Automatic Parts Loader and navigate to Job Run tab.Press INSERT to put run a program in APL Mode.The following is a example of a program using the M299 code:
o00010 (APL LOAD UNLOAD);
G00 G53 X0 Y0 Z0;
T101;
M19 P90.;
G54;
G00 Z1.5;
X0.;
G98;
G01 Z-0.5 F50.;
G04 P1.;
M11;
M10;
G04 P1.;
M11;
M10;
G04 P1.;
G00 Z1.5;
G00 G53 X0. Y0.;
G00 G53 Z0;
M299 (PART SWAP);
