G-code, M-code, and Setting
Service Home M321 / M322 Engage/Disengage Tow Along Tailstock
M321 / M322 Extend/Retract Tailstock Quill
M321 will move the tailstock and then extent the quill.M322 will retract the quill and then move the tail stock.P - Sets a machine position to move the tailstock. If no P code is specified the position will be set by setting 341 for M321 and by setting 105 for M322.
This example will retract the quill then move the tailstock to the machines 0.0 position on the tail stock axis.
M322 P0.0
NOTE: M322 is also used to move the tail stock. If the quill is retracted and M322 is called the quill will stay retracted and the machine will move the tailstock to the commanded position.
NOTE: These M coded are only available on boxway lathes with a tow along tail stock. Standard lathes will alarm out if they are used.
