G-code, M-code, and Setting
Service Home M388 Through-Spindle Coolant On / M389 Through-Spindle Cool...
M388 Through-Spindle Coolant On / M389 Through-Spindle Coolant Off
M388 turns on through-spindle coolant (TSC), and M389 turns off TSC on a Vertical Mill/Turn center.The control automatically stops the spindle before it executes M388 or M389. The control does not automatically start the spindle again after M389. If your program continues with the same tool after an M389 command, be sure to add a spindle speed command before further motion.
CAUTION: You must use proper tooling, with a through-hole, when you use the TSC system. Failure to use proper tooling can flood the spindle head with coolant and void the warranty.
Sample Program
NOTE: The M388 command should be before the spindle speed command. If you command M388 after the spindle speed command, the spindle starts, then stops, turns on TSC, and then starts again.
T201(TSC Coolant Through Drill);
M388 (Turn TSC on);
S4400 M3;
G04 P10. (Dwell for 10 seconds);
M389 (Turn TSC off);
M30;
