G-code, M-code, and Setting
Service Home M69 Turn Off Output Relay
P - Discrete output relay number from 0 to 255.
M69 turns off a relay. An example of its usage is M69 P12nnn, where nnn is the number of the relay being turned off.When using Macros, M69 P12003 does the same thing as using the optional macro command #12003=0, except that it is processed in the same order as axis motion.
Built-In M-Code Relays 8M PCB Relay Bank 1 (JP1) 8M PCB Relay Bank 2 (JP2) 8M PCB Relay Bank 3 (JP3)
P114 (M121) P90 P103 P79
P115 (M122) P91 P104 P80
P116 (M123) P92 P105 P81
P113 (M124) P93 P106 P82
P112 (M125) P94 P107 P83
P4 (M126) P95 P108 P84
- P96 P109 P85
- P97 P110 P86
