G-code, M-code, and Setting
Service Home M78 / M79 Alarm if Skip Signal Found/Not Found
This M-code is used with a probe. M78 generates an alarm if a programmed skip function (G31) receives a signal from the probe. This is used when a skip signal is not expected, and may indicate a probe crash. M79 generates an alarm if a programmed skip function (G31) did not receive a signal from the probe. This is used when the lack of the skip signal means a probe positioning error. These codes can be placed on the same line as the skip G-code or in any block after.M78/M79 Alarm if Skip Signal Found/Not Found: [1] Signal not found, [2] Signal found.
