G-code, M-code, and Setting
Service Home M99 Subprogram Return or Loop
This code has three main uses:1. An M99 is used at the end of a subprogram, local subprogram, or macro to return back to the main program.
2. An M99 Pnn jumps the program to the corresponding Nnn in the program.
3. An M99 in the main program causes the program to loop back to the beginning and run until [RESET] is pressed.
Programming Notes - You can simulate Fanuc behavior by using the following code:
Haas Fanuc
Calling program: O0001 O0001
N50 M98 P2 N50 M98 P2
N51 M99 P100 ...
... N100 (continue here)
N100 (continue here) ...
... M30
M30
Subprogram: O0002 O0002
M99 M99 P100
M99 With Macros - If the machine is equipped with the optional macros, you can use a global variable and specify a block to jump to by adding #nnnnn = dddd in the subprogram and then using M99 P#nnnnn after the subprogram call.
