G-code, M-code, and Setting
Service Home M03 Spindle Fwd / M04 Spindle Rev / M05 Spindle Stop
M03 turns the spindle on in the forward direction.
M04 turns the spindle on in the reverse direction.
M05 stops the spindle, and waits for it to stop.
Spindle speed is controlled with an S address code; for example, S5000 commands a spindle speed of 5000 RPM.
NOTE
If your machine has a gearbox, the spindle speed you program determines the gear that the machine uses, unless you use M41 or M42 to override gear selection. Refer to M41 / M42 Low / High Gear Override for more information on the gear select override M-codes.
NOTE
The Desktop Mill's Spindle should not be run slower than 1500 RPM. At low speeds, the VFD that controls the will supply too much current to the spindle motor. This high current will damage the spindle and eventually cause it to fail.
