G-code, M-code, and Setting
Service Home M08 Coolant On / M09 Coolant Off
P - M08 Pn
M08 starts the optional coolant supply and M09 stops it.
NOTE: The control checks the coolant level only at the start of a program, so a low coolant condition will not stop a running program.
CAUTION: Do not use straight or "neat" mineral cutting oils. They cause damage to rubber components in the machine.
The following applies to machines equipped with the Variable Flow Coolant option. The variable flow coolant option allows the user to operate the coolant pump at different speeds to increase or decrease the flow of coolant.An optional P-Code can be specified along with an M08 to change the speed of the coolant pump.M08 P0 = Low Pressure - The pump will operate at 50HZ speed.
M08 P1 = Normal Pressure - The pump will operate at 60HZ speed.
M08 P2 = High Pressure - The pump will operate at 80HZ speed.
NOTE: If no P-Code is specified, or the specified P-Code is out of range, then normal pressure will be used.
NOTE: If the machine is not equipped with a Variable Frequency Drive for the coolant pump, then the P-Code will have no effect.
