G-code, M-code, and Setting
Service Home M19 Orient Spindle (Optional P and R Values)
P - Number of degrees (0 - 360)
R - Number of degrees with two decimal places (0.00 - 360.00).
M19 adjusts the spindle to a fixed position. The spindle only orients to the zero position without the optional M19 orient spindle feature. The orient spindle function allows P and R address codes. For example:
M19 P270. (orients the spindle to 270 degrees) ;
The R-value allows the programmer to specify up to two decimal places; for example:
M19 R123.45 (orients the spindle to 123.45 degrees) ;
NOTE: The range for M19 is 0 to 360 degrees. If a negative value if given, it will be ignored and spindle will orient to 0 degrees.
