G-code, M-code, and Setting
Service Home M50 Pallet Change Sequence
* P - Pallet number
*indicates optional
This M-code is used to call a pallet change sequence. An M50 with a P command will call a specific pallet. M50 P3 will change to pallet 3, commonly used with Pallet Pool machines.
M50P0 is a special code used to extract a pallet without loading the next one. Use this code when you want to run a wash-down program or a spindle fan to clean the receiver before loading the next pallet while the machine is in pallet mode (M199).
M96 Jump If No Input can be used in conjunction with M50P0 to skip the wash-down program if your are not in pallet mode. Refer to the M96 help text for more information on how to program a wash-down cycle to clean the receiver.
