G-code, M-code, and Setting
Service Home M59 Set Output Relay
M59 Turn On Output Relay
P - Discrete output relay number.
M59 turns on a discrete output relay. An example of its usage is M59 Pnnn, where nnn is the relay number being turned on.
When using Macros, M59 P90 does the same thing as using the optional macro command #12090=1, except that it is processed at the end of the line of code.
Built-In M-Code Relays 8M PCB Relay Bank 1 (JP1) 8M PCB Relay Bank 2 (JP2) 8M PCB Relay Bank 3 (JP3)
P114 (M21) P90 P103 P79
P115 (M22) P91 P104 P80
P116 (M23) P92 P105 P81
P113 (M24) P93 P106 P82
P112 (M25) P94 P107 P83
P4 (M26) P95 P108 P84
- P96 P109 P85
- P97 P110 P86
