G-code, M-code, and Setting
Service Home M70 Workholding Clamp / M71 Workholding Unclamp
Use M70/M71 to clamp or unclamp the vises setup on the workholding page.P - The P code defines the vise number. The range is P1 - 8.
Q - The Q code enables or disables the vise unclamp check when commanding the spindle. Q = 0 or not specified: Enable Unclamp Check. Q = 1: Disable Unclamp Check.
Example:M70 P1 clamps Vise 1 and M71 P1 unclamps it.Example:M71 P1 Q1 disables the unclamp check for Vise 1.
NOTE: The Vise Safety Check will be restored after Power Cycle, Program End(M02,M30), End of Program, Alarms, Reset is pressed, or workholding commands.
NOTE: The system will default to Vise 1, if no P-Code is specified with M70 or M71.
NOTE: This M code is not affected by the status of setting 389. See table below for more details.
Setting 389 M71 Q-Code Message on Cycle start Alarm 9938.001 when is commanded Spindle
Off Q0 No Yes
Off Q1 No No
On Q0 Yes Yes
On Q1 Yes No
