      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
G-code, M-code, and Setting
Service Home M70 Workholding Clamp / M71 Workholding Unclamp
Use M70/M71 to clamp or unclamp the vises setup on the workholding page.
P - The P code defines the vise number. The range is P1 - 8.
Q - The Q code enables or disables the vise unclamp check when commanding the spindle. Q = 0 or not specified: Enable Unclamp Check. Q = 1: Disable Unclamp Check.
Example:M70 P1 clamps Vise 1 and M71 P1 unclamps it.
Example:M71 P1 Q1 disables the unclamp check for Vise 1.
NOTE
The Vise Safety Check will be restored after Power Cycle, Program End(M02,M30), End of Program, Alarms, Reset is pressed, or workholding commands.
NOTE
The system will default to Vise 1, if no P-Code is specified with M70 or M71 .
NOTE
This M code is not affected by the status of setting 389. See table below for more details.
Setting 389 M71 Q-Code Message on Cycle start Alarm 9938.001 when is commanded Spindle
Off Q0 No Yes
Off Q1 No No
On Q0 Yes Yes
On Q1 Yes No
