G-code, M-code, and Setting
Service Home 101 - Feed Override -> Rapid
Pressing [HANDLE FEED] , with this setting ON, will cause the jog handle to affect both the feedrate and the rapid rate overrides. Setting 10 affects the maximum rapid rate. The rapid rate cannot exceed 100%. Also, [+10% FEEDRATE] , [- 10% FEEDRATE] , and [100% FEEDRATE] change the rapid and feed rate together.
