G-code, M-code, and Setting
Service Home 113 - Tool Change Method
This setting is used for the TL-1 and TL-2 lathes. This setting selects how a tool change is executed.
A selection of Auto defaults to the automatic tool changer on the machine.
A selection of Gang Tl allows you to implement a Gang Tl tool changer. A Gang Tl consists only of a change in tool offsets:
  • T12 switches to tool 12 and uses the offset from tool 12
  • T1213 switches to tool 12 and uses the offset from tool 13
  • T1200 switches to tool 12 and uses no tool offset
A selection of Tl Post allows for a manual tool change operation. When a tool change is executed in a program, the machine will stop at a tool change and prompt you to load the tool. Load the spindle and press [CYCLE START] to continue the program.
