G-code, M-code, and Setting
Service Home 131 - Auto Door
131 - Auto Door
131 - Auto Door
When this setting is set to ON:
  • the Auto Door closes when [CYCLE START] is pressed
  • the Auto Door opens when the program reaches an M00, M01 (with Optional Stop turned ON), M02, or M30 and the spindle has stopped turning.
When this setting is set to OFF:
  • The above functions are disabled.
  • Lathe:To use M85/ M86 Auto Door Open / Close M-codes during automation.
NOTE
The Auto door Open/Close M-codes work only while the machine receives a cell-safe signal from a robot or if it has a light curtain installed. For more information refer to Robot Integration Aid - NGC reference document on the service site.
NOTE
The Auto door button will Open/Close the door regardless if setting 131 is set to On or OFF, except if the machine has the HE patch installed. When machine has the HE patch enabled the Auto door button will be disabled.
