G-code, M-code, and Setting
Service Home 142 - Offset Chng Tolerance
This setting is intended to prevent operator errors. It generates a warning message if an offset is changed by more than the setting s value, 0 to 3.9370 inches (0 to 100 mm). If you change an offset by more than the entered amount (either positive or negative), the control prompts: XX changes the offset by more than Setting 142! Accept (Y/N)?
Press [Y] to continue and update the offset. Press [N] to reject the change.
