G-code, M-code, and Setting
Service Home 162 - Default To Float
When this setting is ON, the control will interpret the interger code as if it had a decimal point. When the setting is OFF, values after address codes that do not include decimal points are taken as machinist's notation;
for example, thousandths or ten-thousandths.
Value entered With Setting Off With Setting On
In Inch mode X-2 X-.0002 X-2.
In MM mode X-2 X-.002 X-2.
This feature applies to these address codes:
X, Y, Z, A, B, C, E, I, J, K, U, W
Including A and D except when:
  • the A value (tool angle) is in a G76 block. If a G76 A value containing a decimal point is found during program execution, Alarm 605 - Invalid Tool Nose Angle is generated.
  • the D value is in a G73 block.
NOTE
This setting affects the interpretation of all programs. It does not alter the effect of Setting 77 - Scale Integer F.
