G-code, M-code, and Setting
Service Home 241 - Tailstock Hold Force
Force to apply to a part by the servo tailstock (ST-40/45, ST-40L/40L and ST-50/55 only). Unit is pounds-force in standard mode and Newton in metric mode, as per Setting 9.
Servo Tailstock Specifications
Min Thrust (Programmable Minimum) Max Thrust (Programmable Maximum)
1000 lb / 4448 N 3000 lb (13345 N) - 3500 lb (15569 N)
NOTE
Machines with a servo driven tailstock the max thrust is calculated by the control based on motor parameters. Not all machines will have the same max tail stock hold force.
