G-code, M-code, and Setting
Service Home 245 - Hazardous Vibration Sensitivity
This setting has (3) levels of sensitivity for the hazardous vibration accelerometer in the machine's control cabinet: Normal, Low, or Off. The value defaults to Normal at each machine power-up.You can see the current g force reading on the Gauges page in Diagnostics.Depending on the machine, vibration is considered hazardous when it exceeds 600 - 1,400 g. At or above the limit, the machine gives an alarm.If your application tends to cause vibration, you can change Setting 245 to a lower sensitivity to prevent nuisance alarms.
