G-code, M-code, and Setting
Service Home 252 - Custom Subprogram Search Location
This setting specifies the subprogram search locations when Setting 251 is set to Setting 252. To make changes to this setting, highlight Setting 252 and press the [RIGHT] cursor. The Setting 252 popup explains how to delete and add search paths and lists existing search paths.To delete a search path:1. Highlight the path listed in the Setting 252 popup.
2. Press [DELETE] .
If there is more than one path to delete, repeat steps 1 and 2.To set a new path:1. Press [LIST PROGRAM] .
2. Highlight the directory to add.
3. Press [F3] .
4. Select Setting 252 add and press [ENTER] .
To add another path, repeat steps 1 through 4.
NOTE: When you use M98:The P code (nnnnn) is the same as the program number (Onnnnn) of the subprogram.
If the subprogram is not in memory, the file name must be Onnnnn.nc. The file name must contain the O, leading zeros and .nc for the machine to find the subprogram.
