G-code, M-code, and Setting
Service Home 317 - Max User Travel Limit B
This setting lets you define a custom travel limit position for the B-Axis.
To set this limit with the Steadyrest installed. Jog the B-Axis to the Steadyrest and then hit [F2] on Setting 317 to set value to current axis position.
Press the [ORIGIN] button to set this setting to inactive. Setting this limit to Inactive allows for full travel of the B-Axis. Remove the Steadyrest to prevent any possible collisions or pushing of the Steadyrest off of the guides.
NOTE
This setting is in the User Positions tab under Settings . Refer to User Positions for more information.
WARNING
Incorrectly set User Positions can cause machine crashes. Set user positions with caution, especially after you have changed your application in some way.
