G-code, M-code, and Setting
Service Home 323 - Disable Notch Filter
When this setting is On, the notch filter values are set to zero. When this setting is Off, it uses the default values of the machine as set defined by parameters. Turning this setting On will improve circular accuracy and turning Off will improve surface finish.
NOTE
You must cycle power for this setting to take effect.
