G-code, M-code, and Setting
Service Home 325 - Manual Mode Enabled
Turning this setting ON allows the axes to be jogged without zero returning the machine (finding machine home).The jog limits imposed by setting 53 Jog W/O Zero Return will not apply. The jog rate will be defined by the eWheel switch or the jog rate buttons (if the eWheel is not connected).With this setting ON you can perform tool changes using the [ATC FWD] or [ATC REV] buttons.When turning this setting OFF the machine will operate as normal, and will require to be zero return.
