G-code, M-code, and Setting
Service Home 414 - Sub Spindle Load Type
This setting allows the user to calibrate the Sub Spindle performance across different chuck and part sizes. The choices are:
  • Default - Recommended when using a standard size chuck and part.
  • Calibrated - Recommended when using a large or small size chuck or collet and a large or small part.
For step by step instructions on how to set this setting refer to procedure or scan the code below with your mobile device:Lathe - Spindle Inertia Load Type Setting
WARNING
If the load calibration is incorrect the most likely symptoms could be unstable spindle orient, or a sub spindle drive overvoltage alarm.
