G-code, M-code, and Setting
Service Home 448 - Tailstock Engagement Tool Number
This setting allows you to define a safe tool number to change into before commanding the tow along Tailstock to engage. A value of 0 means that no tool change will occur. Use this position to avoid collisions with fixtures, tailstock, and other potential obstacles. The control uses this position for every tailstock engagement, no matter how it is commanded (Mechanisms page, M321/M322, etc.). Set user positions with caution, especially after you have changed your application in some way (new program, different tools, etc.). Verify and change each axis position separately.
NOTE
This setting only works on Box Way Lathes with a tow along tail stock.
