G-code, M-code, and Setting
Service Home 53 - Jog w/o Zero Return
Turning this setting ON allows the axes to be jogged without zero returning the machine (finding machine home). This is a dangerous condition as the axis can be run into the mechanical stops and possibly damage the machine. When the control is powered up, this setting automatically returns to OFF.
With Setting 53 turned on the control will have the Z axis selected once [HANDLE JOG] is selected.
WARNING
For machines with H-5AX spindle heads it may be necessary to vector jog the machine if the head is oriented in a way that would crash the machine if it did a normal zero return. To do this type [VJ] and press [Handle Jog]. This will put the machine into vector jogging mode so it can be moved free of any obstructions and zero returned.
