G-code, M-code, and Setting
Service Home 73 - G68 Incremental Angle
This setting allows the G68 rotation angle to be changed for each commanded G68. When this switch is ON and a G68 command is executed in the Incremental mode (G91), the value specified in the Raddress is added to the previous rotation angle. For example, an R value of 10 causes the feature rotation to be 10 degrees the first time commanded, 20 degrees the next time, etc.
NOTE
This setting must be OFF when you command an engraving cycle ( G47 ).
