G-code, M-code, and Setting
Service Home 75 - 9xxxx Progs Single BLK
When Setting 75 is ON and the control is operating in Single Block mode, then the control stops at each block of code in a macro program (O9xxxx) and waits for the operator to press [CYCLE START] . When Setting 75 is OFF the macro program is run continuously, the control does not pause at each block, even if Single Block is ON. The default setting is ON.When Setting 74 and Setting 75 are both ON, the control acts normally. That is, all blocks executed are highlighted and displayed, and when in Single-Block mode there is a pause before each block is executed.When Setting 74 and Setting 75 are both OFF, the control executes 9000 series programs without displaying the program code. If the control is in Single-Block mode, no single-block pause occurs during the running of the 9000 series program.When Setting 75 is ON and Setting 74 is OFF, 9000 series programs are displayed as they are executed.
