G-code, M-code, and Setting
Service Home 108 - Quick Rotary G28
If this setting is ON, the control returns the rotary axes to zero in +/-359.99 degrees or less.
For example, if the rotary unit is at +/-950.000 degrees and a zero return is commanded, the rotary table rotates +/-230.000 degrees to the home position if this setting is ON.
NOTE
The rotary axis returns to the machine home position, not the active work coordinate position.
NOTE
This function only works when used with a G91 and not a G90 .
