G-code, M-code, and Setting
Service Home 188, 189, 190 - G51 X, Y, Z SCALE
You can scale the axes individually with these settings (the value must be a positive number).Setting 188 = G51 X SCALESetting 189 = G51 Y SCALESetting 190 = G51 Z SCALEIf setting 71 has a value, then the control ignores Settings 188 - 190, and it uses the value in setting 71 for scaling. If the value for setting 71 is zero, then the control uses Settings 188 - 190.
NOTE: When settings 188-190 are in effect, only linear interpolation, G01, is allowed. If G02 or G03 is used, alarm 467 is generated.
