G-code, M-code, and Setting
Service Home 251 - Subprogram Search Location
This setting specifies the directory to search for external subprograms when the subprogram is not in the same directory as the main program. Also, if the control cannot find an M98 subprogram, the control looks here. Setting 251 has (3) options:
  • Memory
  • USB Device
  • Setting 252
For the Memory and USB Device options, the subprogram must be in the root directory of the device. For the Setting 252 selection, Setting 252 must specify a search location to use.
NOTE
When you use M98 :
  • The P code ( nnnnn ) is the same as the program number ( Onnnnn ) of the subprogram.
  • If the subprogram is not in memory, the file name must be Onnnnn.nc . The file name must contain the O, leading zeros and .nc for the machine to find the subprogram.
