G-code, M-code, and Setting
Service Home 255 - MRZP X Offset
255 - MRZP X Offset
255 - MRZP X Offset
Setting 255 defines the distance, in inches or millimeters, between theB tilt axis centerline and the X-Axis home position for a B/C axis UMC, or
C rotary axis centerline and the X-Axis home position for an A/C axis trunnion.
Use macro value #20255 to read the value of Setting 255.[B] Tilt Axis, [C] Rotary Axis. On a UMC-750 (shown), these axes intersect approximately 2" above the table. [255] Setting 255 is the distance along the X Axis between machine zero and the [B] tilt axis centerline. For [A] Tilt Axis, [C] Rotary Axis on a Trunnion, [255] Setting 255 is the distance along the X Axis between machine zero and the [C] axis centerline. This illustration is not to scale.
NOTE: When touching off tools or working on the stationary table, make sure the tilt axis is at 0 degrees (A0 or B0).
