G-code, M-code, and Setting
Service Home 257 - MRZP Z Offset
257 - MRZP Z Offset
257 - MRZP Z Offset
Setting 257 defines the distance, in inches or millimeters, between the
  • B tilt axis and the Z-Axis home position for a B/C axis UMC, or
  • A tilt axis and the Z-Axis home position for an A/C axis trunnion
Use macro value #20257 to read the value of Setting 257.
[B] Tilt Axis, [C] Rotary Axis. On a UMC-750 (shown), these axes intersect approximately 2" above the table. [257] Setting 257 is the distance along the Z Axis between machine zero and the [B] tilt axis. For [A] Tilt Axis, [C] Rotary Axis on a Trunnion, [257] Setting 257 is the distance along the Z Axis between machine zero and the [A] tilt axis. This illustration is not to scale.
NOTE
When touching off tools or working on the stationary table, make sure the tilt axis is at 0 degrees (A0 or B0).
