G-code, M-code, and Setting
Service Home 28 - Can Cycle No Linear Axes
This is an ON/ OFF setting. The preferred setting is ON.When it is OFF, the initial canned cycle definition block requires an X or Y code for the canned cycle to be executed.When it is ON, the initial canned cycle definition block causes one cycle to be executed even when there is no X or Y code in the block.
NOTE: When an L0 is in that block, it will not execute the canned cycle on the definition line. This setting has no effect on G72 cycles.
