G-code, M-code, and Setting
Service Home 295 - Tool Change Mid Position Z
This setting lets you define a safe position for the Z axis at a tool change command, before the axes go to their final tool change positions. Use this position to avoid collisions with fixtures, trunnions, and other potential obstacles. The control uses this position for every tool change, no matter how it is commanded (M06, [Next Tool] , etc.)
Press the [ORIGIN] button to set this setting to inactive or set the complete group to inactive.
NOTE
This setting is in the User Positions tab under Settings . Refer to User Positions for more information.
CAUTION
Incorrectly set user positions can cause machine crashes. Set user positions with caution, especially after you have changed your application in some way (new program, different tools, etc.). Verify and change each axis position separately.
